My 2012 Jayco Seneca Super C motorhome that sits on the Freightliner M2 chassis had an issue with the brake lights stuck in the on position, even when the vehicle was turned off.
Turning the ignition on, didn’t solve the problem and the brake lights still stayed illuminated regardless.
The vehicle is equipped with hydraulic brakes and an air brake for the parking brake.
So I replaced the brake light switch that was located on the brake pedal itself, and that did not change or solve the problem.
Next, I changed the parking brake switch and that did not solve the problem.
Next, I replaced the chassis module, which is located on the frame rail of the driver side, and that also did not solve the problem.
It turns out that the brake module that’s located in the dashboard behind the instrument panel failed and that’s what was causing the problem.
So once that was replaced, everything returned to normal and the problem was solved.
Hopefully this will help somebody solve the similar issue.
Brake Module P/N POL3201201
