I suppose you’ve heard that our Rep. Herseth Sandlin is one of seven Democrats accompanying Nancy Pelosi on a junket to Europe, courtesy of the taxpayers, to discuss global warming with politicians in Germany, Belgium and Greenland. I understand these politicos are worried about the glaciers in Greenland melting! After I got over being worked up over the waste of my tax dollars, I realized just how funny that idea is.
##### Dreiling sent me this a while ago and with these liberal do-gooders running off to Europe at the taxpayer’s expense at the same time we are honoring those who serve in the military, I just had to share it with you:
A US Air Force C-141 is scheduled to leave Thule Air Base, Greenland, at midnight. During the pilot's preflight check, he discovers that the latrine holding tank is still full from the last flight.
So a message is sent to the base, and an airman who was off duty is called out to take care of it.
The young man finally gets to the air base and makes his way to the aircraft, only to find that the latrine pump truck has been left outdoors and is frozen solid, so he must find another one in the hangar, which takes even more time.
He returns to the aircraft and is less than enthusiastic about what he has to do. Nevertheless, he goes about the pumping job deliberately and carefully (and slowly) so as to not risk criticism later.
As he's leaving the plane, the pilot stops him and says, "Son, your attitude and performance has caused this flight to be late, and I'm going to personally see to it that you are not just reprimanded, but punished."
Shivering in the cold, his task finished, he takes a deep breath, stands up tall and says, "Sir, with all due respect, I'm not your son; I'm an Airman in the United States Air Force. I've been in Thule, Greenland for eleven months without any leave, and reindeer are beginning to look pretty good to me. I have one stripe; it's two-thirty in the morning, the temperature is 40 degrees below zero, and my job here is to pump s--- from your aircraft.
Now just exactly what form of punishment did you have in mind? Sir!!
