E-Track installation question
Twmaster
I just purchased a nice used GMC 3500 with a 10' Morgan FRP body and need to install some cargo management equipment.
I would like to install E-Track both close to the floor (per another post here on EO) and just under the existing tie-off rail. Since the body is fiberglass reinforced plywood (FRP) what would be the recommended method of securely attaching the E-Track to the sidewalls without compromising the strength of the wall material? (or am I worriing too much? ;) )
Mike N
Glen Rice
You should probably check with the manufacturer of the body and get there recommendations. You may have to install a furring strip first, and then anchor to that strip, this will distribute the pulling force over a broader space instead of pulling directly on the side wall, which would probably brake the wall. Just my opinion, so better be safe than sorry?
