Most have a thin metal cord. Just pull that cord until the air stops coming out. Usually the cord is located by the fuel tank. If you see a little moisture on the ground don't be alarmed, but I would check and make sure no motor oil was in there. Belive it or not motor oil can manage to find its way to your air tank. If that happens it's best to take it to a good mechanic to figure out what the problem is.
