Yes, I don't know why Freightliner used those plastic fuel lines near the engine which moves and vibrates a little bit and wears holes in them. I bent and moved the metal holder brackets a bit on mine to be sure the lines did not contact anything. That solenoid is another story, one yet to be answered. The "new" style, made physically bigger, did not last as long as the older small one did. At $250 a pop those things should be outlawed. My dad had his changed to the Ford 7000 style, which mounts the solenoid on the front of the fuel pump and uses a long actuator rod so it pulls horizontally. We will see if that makes it last any longer. It really does confuse you when the solenoid starts getting intermittent and doesn't pull the arm up all the way. I remember going through the fuel filter, injector routine the first time it happened to me. There are two electrical legs to it (three wires) a start and a run mode. When the run coil dies the truck will start but stall immidiately. When the start coil dies the engine will usually still start, but the arm won't come up all the way and the engine will have no power as it doesn't have full fuel flow. When it all dies you bungee cord the arm up, and open the hood and stop the engine by pushing the arm down. Fun! Bosch was a great mechanical fuel injection system though, it has a place in my heart. But the electronic systems eliminate it's three worst problems- throttle cable, return springs, and that friggin' solenoid. That spring loaded throttle arm can be a pain sometimes too.
-Weave-
