It rained yesterday, also today it's raining. I went out to start my van this morning and it wouldn't fire. Or it did, ran like garbage for a few seconds and then shut down.
After getting the doghouse off, my landlord brought out his heater and we aimed that at the distributor and the coil. With some difficulty we got the engine to start (it had flooded some into the bargain) and run. It smoothed out, and we heard quite a good bit of high-tension sparking for a couple of minutes. Then that went away as the engine dried out.
I've replaced the cap and the rotor, both of which have seen high mileage and needed replacing. I'm not sure what else may need to be replaced before this is over and done with, in times past wet ignition troubles and bum coils seem to have gone together. Not sure if I ought to replace that critter too. Any ideas?
Right now, with the new cap and rotor, it runs smoothly enough.
Edit; add-on: I should mention this is a 1998 Chevy Express, 2500, with the 5.7 engine.
