MBE900 EGR COOLER PROBLEMS
Discussion in 'Truck Talk' started by NEVERHOME247, Oct 15, 2005.
  1. NEVERHOME247
    NEVERHOME247 Veteran Expediter Charter Member
    Nov 30, 1999
    145
    133
    Ratings:
    +0 / 0 / -0
    ANYONE HAD PROBLEMS WITH MBE900 EGR COOLER GOING BAD? JUST CURIOUS IF ANYONE WHO HAS A MBE900 HAS HAD ANY PROBLEMS WITH EGR COOLERS. HAD ONE GO BAD AT 70k AND AGAIN @ 140K. SEEMS TO BE A 70k MILE PROBLEM. EGR COOLER LEAKS COOLANT INTERNALY. BOTH REPAIRS UNDER WARRANTY. PARTS WERE ABOUT $2K. WILL BE EXPENSIVE WHEN NOT UNDER WARRANTY. I AM TRYING TO ESTABLISH IF THIS IS A WIDE SPREAD PROBLEM WITH THIS PARTICULAR ENGINE.
  2. LDB
    LDB Veteran Expediter Retired Expediter
    Sep 11, 2004
    16,013
    755
    Ratings:
    +2,931 / 1 / -0
    Vehicle:
    Recliner
    I've got 90k on mine and no problems so far, knock on wood.
    p.s. If you'll turn off your caps lock key your posts will be easier to read.
    Leo Bricker
    OOIDA 677319
    truck 4958
    73's K5LDB
  3. jaminjim
    jaminjim Veteran Expediter
    Mar 25, 2002
    3,437
    265
    Ratings:
    +706 / 0 / -0
    245K on ours, nothing yet, Knock on wood.
  4. davekc
    Caffeine Fix
    Nov 6, 2001
    15,044
    1,005
    Ratings:
    +5,163 / 0 / -0
    Carrier:
    Panther & V3
    Vehicle:
    Lazy-Boy
    It sounds like it is idling at too low of RPM. It probably needs to be a little higher. This was a common problem on some M2's. You can buy a device to raise and lower your idle manually, or you will have to have the dealer adjust your computer.
Loading...
Similar Threads - MBE900 COOLER PROBLEMS
  1. hossman2011
    13
    1,953
  2. redytrk
    4
    981
  3. cornerstone
    1
    998
  4. Weave
    8
    1,647
Share This Page
