Recently I disconnected my battery cables, pulled the speedometer out to look for something else and now my check engine light and engine heater light won't go out and the code it flashes is 49 which is "Inlet Air Heater Driver Fault" (open/closed circuit) or something like that.
I called CAT and he said it could be anything related to it (air heater) but that it was safe to drive.
Where is the air heater located?
When you turn the key you can hear it click like 6 times then I start it and it starts fine. But the heater and check engine lights stay on.
Suggestions?
Suggestions?
