Several items come to mind that can cause the slack and pedal noise; First the throwout bearing & cross shaft or shift fork. The ears, pads on the fork or whatever you want to call them do wear quite a bit over time. Adjustment helps for a while......
The clutch brake wears out (it is the little metal disc with friction surfaces that goes between the BACK of the throwout bearing and input shaft bearing housing on the tranny). Its function is to stop the input shaft rotation to allow you to get in first gear and indicated by the grinding noise you hear and feel shifting into gear before takeoff.
The attaching bolts, yokes, bellcranks, hiem joints, clutch cable (for those with a cable) stretches out. The old style linkage can be a real pain in any mechanics rear. Especially when another mechanic has adjusted it to compensate for the travel distance of the pedal.
Redoing or getting it neutralized properly (the linkage) is a time consuming affair by the way and should be done at every clutch replacement interval. That insures that you recieve maximum life from the clutch asy.
How many O/O's & drivers grease the throwout bearing, clutchfork bushings and linkage attachment points regularly? Little tip about the throwout bearing being greased. Many pump grease until they see it appear at the back or front of the bearing.
3 strokes of a manual lever gun is safe, anymore you run the risk of wetting your clutch assy with grease, then the cussing begins later down the road. 4 or 5 strokes for the cross shaft bushings too. Its ok there if you see a hint of grease at those.
I apologise for the length of the reply. Hope it helps everyone to understand.
(I'll go hunt my Spicer factory manuals & double check Ok?).
