Rust in Fuel Lines 2011 Hino 268A
Discussion in 'Hino Trucks' started by NBP536, Aug 1, 2018.
  1. NBP536
    NBP536 New Recruit Driver
    Aug 1, 2018
    2
    1
    Ratings:
    +0 / 0 / -0
    Vehicle:
    2011 Hino 268A
    Truck just had serviced and DOT inspection a couple of weeks ago at an independent shop. After a couple of weeks the water in fuel light came on. Decided to take the truck in to dealer for an oil leak (developed after connecting rod recall work), and water in fuel light. Shop agreed to fix the leak under warranty. While working on the gasket, the mechanic noticed the fuel filter (which had just been replaced) was dirty. When replacing the filter the mechanic said he saw "excessive contamination". They are recommending replacing the fuel tank and everything from the fuel tank to the motor basically to the tune of $9500.
    Is there a reason you couldn't just flush the system? And why would you replace aluminum tanks?
  2. greasytshirt
    Dr Pepper Addict
    greasytshirt Moderator Staff Member Mechanic
    Dec 3, 2013
    2,158
    220
    Ratings:
    +722 / 0 / -0
    I could see an argument for replacing the steel tanks because those rust pretty badly. Aluminum, no. If an aluminum tank is dirty, I'd just take it off and steam clean it as thoroughly as possible, dry it out, and reinstall it.
    • NBP536
      Aug 1, 2018
      2
      1
      Ratings:
      +0 / 0 / -0
      Vehicle:
      2011 Hino 268A
      Thanks for your answer. I spoke with them, apparently the stand pipes are extremely rusted and they cannot buy them individually and need to order the whole tank assemblies.
    • greasytshirt
      Dr Pepper Addict
      Dec 3, 2013
      2,158
      220
      Ratings:
      +722 / 0 / -0
      Unless they have holes in them, I still don't think they warrant replacement.
    • Hino123
      Hino123 Active Expediter Researching
      Dec 26, 2016
      127
      50
      Ratings:
      +34 / 0 / -0
      Junkyard trip!
    Loading...
    Share This Page
