Heating / Cooling Rooftop A/C unit that will run off a 2000 watt generator
Discussion in 'The Tech Shop' started by interstategar, May 11, 2015.
  1. interstategar
    interstategar Veteran Expediter
    Jan 1, 2008
    179
    135
    Ratings:
    +17 / 0 / -0
    I'm looking for a make and model of a rooftop A/C unit for a cargo van, that can be powered by a Honda 2000 watt generator. Everything I've seen online so far are 11K BTU's than need 2500 watts minimum. Anyone running what I'm looking for?
  2. kg
    kg Veteran Expediter Charter Member Owner/Operator
    Nov 30, 1999
    261
    145
    Ratings:
    +76 / 0 / -0
    Yes. Coleman Mach 9200 btu. Running it with a Yamaha 2000.
    • Turtle
      Busy
      Apr 5, 2006
      24,535
      1,285
      Ratings:
      +12,584 / 12 / -1
      Carrier:
      Load One
      Vehicle:
      2005 Sprinter
      If you get an AC unit that's hard to start, or won't start, you can add a "hard start capacitor" and it'll work. It takes all that stress off the compressor at startup.
      • Like Like x 2
    • gotto_03801
      gotto_03801 Seasoned Expediter
      Nov 9, 2011
      86
      55
      Ratings:
      +7 / 0 / -0
      if your using a Honda EU2000i it's not 2000 watts it's 1600 watts. but I think it's 2100 or 2200 watts surge start up for 10 seconds on start up and I al belive from what Honda told me its 16 amps also
    • xiggi
      Feb 7, 2009
      8,645
      605
      Ratings:
      +4,935 / 4 / -1
      Vehicle:
      Sprinter
      Mines running right now, Coleman Mach 2 or 3 don't remember which. 12500 btu. Honda 2000, works fine. August in laredo I might need to pull the curtain at the rear of my bed so it's cooling a smaller space but that's still the width of the Sprinter and 8 ft long. Insulate well!
      • Like Like x 2
    • xiggi
      Feb 7, 2009
      8,645
      605
      Ratings:
      +4,935 / 4 / -1
      Vehicle:
      Sprinter
      I have the ac on, a tv, powered roof antenna and small light with about 20 leds running right now.
      • Like Like x 2
    • vandriver2
      Apple Fan
      vandriver2 Veteran Expediter Owner/Operator
      Apr 6, 2011
      1,354
      330
      Ratings:
      +1,216 / 0 / -0
      Carrier:
      Bolt-Express
      Vehicle:
      Sprinter 2500 EXT
      Mags an I watching tv in our Sprinter....
    • Windsor
      Windsor Veteran Expediter
      Apr 8, 2015
      901
      155
      Ratings:
      +982 / 2 / -0
      What the hell is an AC?
      • Like Like x 2
    • xiggi
      Feb 7, 2009
      8,645
      605
      Ratings:
      +4,935 / 4 / -1
      Vehicle:
      Sprinter
      Wanted to add that I think my Coleman is called a power saver so I recommend you Google that. I ordered mine from adventurerv.net it was the best price I could find at the time.
      • Like Like x 1
    • in-Transit
      EO4ME
      in-Transit Veteran Expediter Owner/Operator
      Feb 20, 2014
      939
      240
      Ratings:
      +1,946 / 1 / -0
      Vehicle:
      Transit T350
      I must say I agree but the transit is getting a roof mount unit I'm in this dang van more the my own house bout time I got comfy!
      Sent from my flying circus
      • Like Like x 2
    • vandriver2
      Apple Fan
      Apr 6, 2011
      1,354
      330
      Ratings:
      +1,216 / 0 / -0
      Carrier:
      Bolt-Express
      Vehicle:
      Sprinter 2500 EXT
      It's my Office and Hotel Room.
    • Windsor
      Apr 8, 2015
      901
      155
      Ratings:
      +982 / 2 / -0
      Xiggi has a coleman rooftop that works real well. I have a coleman cooler I stick my fat head in when it gets hot
      • Like Like x 5
    • interstategar
      Jan 1, 2008
      179
      135
      Ratings:
      +17 / 0 / -0
      I don't know how you got a 12500 BTU to run on a Honda 2000. The draw needed to start the compressor is more than what the Honda 2000 can put out. Did you add a capacitor to handle the start up electrical load?
    • xiggi
      Feb 7, 2009
      8,645
      605
      Ratings:
      +4,935 / 4 / -1
      Vehicle:
      Sprinter
      Nope it is made by Coleman to run off a 2000. It does not need the typical 30 amp plug.
    • danthewolf00
      Batty
      danthewolf00 Veteran Expediter
      Jul 15, 2008
      1,659
      210
      Ratings:
      +479 / 1 / -1
      Coleman started to put hard start capacitors in the mach 3 i think because of complaints of campers not getting it to run.
    • interstategar
      Jan 1, 2008
      179
      135
      Ratings:
      +17 / 0 / -0
      Great to hear. Will ck out a Coleman mach3. Thanks for the info
    • bubblehead
      bubblehead Veteran Expediter
      Sep 12, 2008
      529
      170
      Ratings:
      +151 / 0 / -0
      Carrier:
      Fedex CC
      Dometic also sells a split system in a 7000, 10000 & 14000 btu rating. A little pricey, but very flexible mounting configurations, easy self install and easy to maintain/service.
      I currently have a 14000 btu unit in a straight truck running off a Honda eu2000i until I get my regular generator repaired.
      The Honda works just fine under the following conditions:
      Set temp to lowest setting to prevent cycling of the compressor,
      Set fan speed to no higher than 2 (on a 3 speed).
      Program the volt tolerance to 127V if not already set for that.
      Keep ECO run on the Honda in the OFF position.
      I get 4.1 hours run time on the .95 gallon tank.
      This is a temporary solution for me until the other Gen gets repaired. The Dometic does not have a hard start capacitor installed. I will add that latter and test run the unit without the previous mentioned conditions.
      If the Gen repair gets ridiculous and the hard start capacitor doesn't resolve the limitations, I will get the eu3100is to replace the Powertech gen and cary the DOT legal limit of 8 gallons fuel for auxiliary equipment.
      According to Dometic, the specs on the 14k unit pulls 14.5 cooling amps I assume this is at highest setting and for the 7 & 10k models, they pull 7.3 and 11.8 amps respectively. http://www2.dometic.com/19a42585-52fc-463f-bbb3-8eebcf39a3a2.fodoc
      They also have a console unit designed to run off 2k inverter which should easily be within the limits of the little Honda. http://www2.dometic.com/enus/Americ...s-Expanded-Line-of-HVAC-Systems-For-Day-Cabs/
      If I was to go to a van in the future, I would likely get the split system and install it myself and put a Max Air fan on the roof.
    • xiggi
      Feb 7, 2009
      8,645
      605
      Ratings:
      +4,935 / 4 / -1
      Vehicle:
      Sprinter
      The specs sound like that' may not be on compressor startup or your 2000 would run it on the 14k setting..
    • bubblehead
      Sep 12, 2008
      529
      170
      Ratings:
      +151 / 0 / -0
      Carrier:
      Fedex CC
      I agree, After the compressor cycles a few times, it will go into overload, that is why I set the temp. to the coldest.
      The unit does not have a hard start capacitor. I am hopeful that when I install that then operation will be normal and run time will increase to over 5 hours.
      It was a quick purchase as I was trying to find a Yamaha 2800 (slightly heavier) because it seems on or near par with the Honda reputation.
      But regardless, it has done better than expected. I am a believer is gasoline powered generators now.
    • Unclebob
      Balanced
      Unclebob Expert Expediter Owner/Operator
      Aug 23, 2013
      316
      130
      Ratings:
      +250 / 0 / -0
      Carrier:
      Crossroads Express
      Vehicle:
      Transit 350
      I just bought a brand new generator to run my 13.5k Dometic rooftop AC.
      Brand name is Champion 2800 watt with 3100 Watts surge power.
      I run it on the economy mode and it does an excellent job running my AC.
      Price on it was $840.00 from amazon.com. It's very quiet and the reviews all gave it very high marks, I'm very satisfied with it.
    Loading...
    Share This Page
