Ditto on the response from pantherrecrtr. I would just like to add that most of the larger expediters do require you to get your hazmat endorsement. If it is not too much of a hastle for you, you might want to consider taking the test. Also, most of the expediting companies if not all allow fleet owners and either the recruiters or someone in qualifications will have a list of fleet owners looking for singles or teams in any type of vehicle. Do you need to run team? My opinion is usually dependant on the individual. Couple things; Where do you live? Can you team with someone you wouldn't mind shareing a small quarters with for a couple weeks at a time? How much money do you need to make? If at all possible, a spouse (if you can stand each other enough) is the ideal situation as far as income is concerned for either owner operator status or driver status. Remember, if you were to drive for an owner operator and had a co-driver, you will be slicing the pie three ways. Is there enough income that can be generated to make all parties happy?
There are a lot of questions that can be asked when looking for a company to sign on with. I do believe there are some older posts that covered most of them.
Good Luck,
ABC
