Promaster 3.6
BXDIVER
K&N now makes the air filter for the Promaster 3.6 engine. My fuel inconomy increased by 3.5 mpg and the throttle response is smoother.
Thanks for info ... will check out next time home
FlyingVan
I bet if you remove the air filter all together your fuel economy will increase even more. K&n improves air flow at the expense of filtration efficiency. Do your engine a favor and use the OEM air filter.
brokcanadian
Countless stories on the internet about letting dust pass. Try coating a thin little film of grease in the piping AFTER the filter, and check how much dust is coating it after your next cleaning...
Strategy would be good for those that trade in often :D
Always follow the money. If Dodge could change filters and boost economy 3 mpg, why wouldn't they do it?
You now have your answer. Stick to the OEM or similar.
Reactions: DollarSign
