Pipe above turbo
Tobster317
I have an 07’. A little different set up but I have oil residue where all the rubber connection are and that’s normal. Maybe there’s a gasket inside where the residue is that is broken?
The 2008 has closed crankcase ventilation, so it's common to find oil residue throughout this piping. If you feel like the amount of residue is excessive, you can add the crankcase filter and breather cap from a 2011 and later truck.
Dejan
its any chance that you can give us some pictures how to install that crankcase filter and a breather cap
thanks
Remove the cap and the piece inside the canister and throw them away. Install the filter and cap from a 2011-newer truck. That's it.
Reactions: Hino123
Hino123
Researching
I attached pics of the parts, part number’s and the pieces you can throw away.
Hino123
Researching
Part #s
