LED bulbs
Rodolfo Auvert
Industry Supplier
Can anybody give his advice on how to successfully buy LED headlight bulbs online? Could you explain, how could I know if the advertised bulb lumens are real? What is a good price for a powerful LED bulb? Should I use AMAZON or I should look for a specialist? Mine are H11...
Could anybody recommend a website to good buy LED bulbs?
Why not go to the nearest parts store of your choice?
natsys
I found headlight revolution to be very informative. I'm not advocating purchasing products they sell, but I learned more about bulb design and construction than I ever realized was involved. There's several videos to watch too. Previously I bought some mid price bulbs and some real cheap ones online. There's a reason why better ones cost more and it can't hurt to get an education or comparison on different products.
Rodolfo Auvert
Industry Supplier
Hi Natsys,
Thanks for answering! If you are aware that better ones are more expensive, what do you look for (online), apart from price, to know that they are better? Also, when you speak about mid-price, what would be your mid or your high-price (good quality) figures?
Thanks again,
Rodolfo
natsys
There's too many considerations to list them all. Heat dissipation, beam dispersal, quality of connectors, electronics packaging, DRL compatibility, indexing for proper alignment and a lot more.
On my Hino I lost the doors behind the headlights so the back of the bulbs were open to the elements and road spray cast off of the tires. The medium quality bulbs I had were not bad--good connectors and beam dispersion, but they used cooling fans which allowed water and debris to be sucked into the headlight housing which sprayed schmoo against the back of the lens. They cost about $70.00. When one went bad I bought a $10.00 set that scattered light everywhere but on the road. They were so bad I decided to drive with only one headlight until I could get another medium quality bulb.
Recently I replaced those with Morimoto 2stroke 3.0 bulbs. They are excellent quality that locate the LED chips exactly where the coil of the original H4 halogen bulbs are along with precision reflector cups so there's a very sharp beam pattern. What I like the best is that they're fully sealed into the housing. They have fan cooling, but the fans take in air from INSIDE the housing and then also expel it into the housing. This prevents sucking in outside debris and also it provides a little heat to help melt snow and ice buildup on the lens like halogen bulbs do.
Each application will vary as well as your preferences and priorities. Like I said earlier, I found the videos covering all these topics and more very informative to compare all kinds of features. You can even browse by what fits your vehicle or for a certain size bulb and get a full rundown on the pros and cons of each manufacturer's bulb including an actual demonstration of the bulb inside a headlamp and what the beam pattern is compared to stock.
For what its worth, the Morimoto's are on sale everywhere for just under $200.00, but there's a lot of good quality bulbs out there. Some that are even higher priced have lifetime warranties. You have to do the research for your needs and vehicle then decide based on your circumstances, priorities, and budget what's the best bulb for you.
