08 runs about a football field then decreases power. 087 checked for air in filter housing had bubbles fixed that still does it oh and when u start it runs perfectly at a idle. U rev it up to 2000rpm I'll lose power. Misses as soon as u give it pedal, changed injector pump pressure sensor relief valve wiggle wires ,pressure sensor changed it so cut wires, have three wire splinters rd in .still does it. Did injector test number 6 works for a little bit then cuts off, resetting key makes it work again any suggestions.. thanks did fuel can test also no difference
