So i have a hino 2008 268a with a injection malfunction #5,after i had swapped it from six mind you. After the swap and the problem followed i got a new injector. Thought problem solved but after running for an hour and down the hwy it came back with same code p0205. I coded the injector,i cleared the codes,not sure if im missing something. I initially changed out six with a new one the day before and it did the same exact thing. Ran great for an hour then came back with same code. I regened it also after the original repair. So thats why i swapped it to five. Am i missing something or doing something wrong? If anyone can help i would be grateful because i would rather burn it to the ground then bring it to fmi again them dirty thiefs.
