HINO BRAKE SENSOR
zenn7
Can anyone enlighten me about the system re. the wear sensor for the rear disc brakes on a Hino 195.
so- is this as complicated as the 20 ,,,,,,,dollar cable that plugs into the brake pad and is often disabled by twisting the two wires together,, to fool the light on the dash?
Or.. If someone told you there was a 500.00 repair kit- might they be pulling your leg? How about 1.5 hours of labour to install this magic in a box?..
thx
I can't find the wear sensor installation in the book. Granted, I spent about 3 minutes looking. I did find them in the wiring diagrams. They're in a series circuit, so you can splice them together if they are worn through.
Jean
Morning sir, regen stops after 5 seconds pulled out spark plugs from burner to clean and they were wet, orange hose from inter cooler has oil coming out any suggestions?
