I have an 2004 FL-112 with a mercedes 900 series engine. When you turn on the key you have to wait for the computer to click and then the gauges to go all the way right then back down , then you can turn the key to start it.(normally).
now when you turn the key it does not click nor do the gauges move...you can however go ahead and crank the engine, but when you do and drive down the road, all the gauges are off,,for example speedometer off by 5mph, tach off by 500rpm, temp off 20 degrees, air pressure off 25, etc.
the only time any one has been near the panel was to replace a couple of instrument light bulbs recently.
any ideas??? thanks frank
