FUZZY NOZZLE?
Discussion in 'Hino Trucks' started by likemlow, Nov 29, 2017.
  1. likemlow
    Caffeine Fix
    likemlow Rookie Expediter Mechanic
    Apr 28, 2017
    29
    15
    Ratings:
    +8 / 0 / -0
    Hi All,
    Again, 2012 Hino 258 with the beloved burner system. The atomizer nozzle that has the steel braided line to it is getting plugged up quite often. When we pull it out it looks like greasy spiky fuzz. We clean it by spraying it down with brake clean, wiping it off with a towel, and injecting brake cleaner through it until the spray pattern returns. What is causing this? We did the burner maintenance 30k miles ago. Any input is greatly appreciated.
  2. BigStickJr
    Dec 23, 2006
    2,477
    430
    Ratings:
    +2,564 / 15 / -1
    When I saw the title, Fuzzy Nozzle, I was going to suggest penecillin.
    I see you have a totally different issue.
    • Ragman
      EO4ME
      Dec 29, 2009
      13,062
      955
      Ratings:
      +16,325 / 12 / -4
      Carrier:
      Retired
      Vehicle:
      Straight truck
      [​IMG]
      • Like Like x 1
    • greasytshirt
      Dr Pepper Addict
      greasytshirt Moderator Staff Member Mechanic
      Dec 3, 2013
      2,158
      220
      Ratings:
      +722 / 0 / -0
    • greasytshirt
      Dr Pepper Addict
      Dec 3, 2013
      2,158
      220
      Ratings:
      +722 / 0 / -0
      So, how are you determining nozzle clogging? A ton of crud on the face of the nozzle is basically normal. Trying to wipe the stuff off of the surface will mash carbon into the orifices, clogging them. Blowing it out with brake cleaner does not always work. There's also an internal, uncleanable filter inside, or so I'm told. Looking at nozzle pressure with DXII is the only sure method to determine if it's clogged.
      If carbon is absolutely covering everything, and the ignitors are shorting out, the engine may need new fuel injectors.
      I've seen where a failing air compressor pumps up the air system with oily air, overcoming the air dryer, pushing oily air into the atomizer and causing it to fail.
      There are many things going on here.
    • likemlow
      Caffeine Fix
      Apr 28, 2017
      29
      15
      Ratings:
      +8 / 0 / -0
      Thanks for the replies. I'll make sure wrap the nozzle up before inserting it in unknown orifices. The symptom we experience is long regen times. Usually the truck regens for 15-20 minutes. Any longer than that it will get stuck trying to regen for hours. So we pull the truck into the shop, clean the nozzle and the truck returns to normal. Lately it seems we have to do this more often.
    • greasytshirt
      Dr Pepper Addict
      Dec 3, 2013
      2,158
      220
      Ratings:
      +722 / 0 / -0
      If it tries to regen for hours, it's misfiring or not coming up to temp quickly enough. Many many things can cause this. Nozzle clogging is one, but that's a tiny part of the pic.
      Where are you located?
    • likemlow
      Caffeine Fix
      Apr 28, 2017
      29
      15
      Ratings:
      +8 / 0 / -0
      We're in Corona CA. We ended up replacing the Atomizer and the nozzle because it was leaking fuel and so much air the truck couldn't build air pressure!! So far so good.
    • greasytshirt
      Dr Pepper Addict
      Dec 3, 2013
      2,158
      220
      Ratings:
      +722 / 0 / -0
      Atomizer replacement is fun, ain't it?
    • likemlow
      Caffeine Fix
      Apr 28, 2017
      29
      15
      Ratings:
      +8 / 0 / -0
      Oh yea! My favorite part is taking off the air line and putting the banjo bolt back in. :)
    • greasytshirt
      Dr Pepper Addict
      Dec 3, 2013
      2,158
      220
      Ratings:
      +722 / 0 / -0
      We put one of the oil change guys on that job once. He flopped around under there for six hours before someone found something else for him to do.
      • Funny Funny x 1
    Loading...
    Share This Page
