Ford Transit 3.5 Oil/Filter Change
Discussion in 'Truck Talk' started by Moot, Jul 11, 2018.
  1. Moot
    Confused
    Moot Veteran Expediter Owner/Operator
    Dec 26, 2005
    10,764
    1,005
    Ratings:
    +7,289 / 5 / -1
    Carrier:
    Panther
    Vehicle:
    Transit 350 Long/Tall Ecoblast
    Changing oil/filter in the Ford Transit with the 3.5 EcoBlaster is a major PIA and also very messy. No matter how careful one is when removing the oil filter, oil ends up on the turbo plumbing, crossmembers, floor and anything else within 10 feet. Today, oil change #29, I finally did it free of any oily mess.
    I've been perfecting a device I made over the past several oil changes. The original consisted of a plastic juice container with the bottom 2 inches cut off. The original cap with a hole drilled in the center and fitted with a rubber grommet through which a Phillips screwdriver was inserted. The idea was to use a hammer to punch a hole in the oil filter with the screwdriver. The problem with this was not much oil drained from the filter without complete removal of the filter resulting in a mess.
    Oil change # 28, instead of a screwdriver I used socket extension through the cap with an oil filter socket connected on the end inside the juice container and a ratchet on the other end. The problem with this was I failed to consider that the turning extension inside the tight fitting grommet caused the cap on the juice container to unscrew resulting in another mess.
    Today I tried again. This time I glued the juice container cap to the threads on the container neck and also hosed down the extension and inside of the grommet with a silicone lubricant. The extension turned freely within the grommet. The capped stayed on. The oil filter was freed from it's threaded nipple and fell into the juice container. No mess!
    • Like Like x 3
  2. BigStickJr
    Dec 23, 2006
    2,552
    455
    Ratings:
    +2,654 / 15 / -1
    George Foreman says call Inventhelp
    • RoadTime
      Paranoid
      Jun 30, 2008
      5,163
      905
      Ratings:
      +8,247 / 10 / -0
      Carrier:
      Load One
      Vehicle:
      Sprinter
      Well that's kind of disturbing to hear. First time I've heard about any issues with changing the oil. Trade secret?
    • Moot
      Confused
      Dec 26, 2005
      10,764
      1,005
      Ratings:
      +7,289 / 5 / -1
      Carrier:
      Panther
      Vehicle:
      • Like Like x 1
    • scottm4211
      scottm4211 Veteran Expediter Owner/Operator
      Jan 20, 2008
      7,416
      655
      Ratings:
      +3,882 / 9 / -3
      Carrier:
      Load One
      Too bad they haven’t gone with the cartridge type filters accessed from up top.
      • Like Like x 2
    • Worn Out Manager
      Amused
      Apr 5, 2015
      4,526
      620
      Ratings:
      +10,595 / 25 / -1
      Carrier:
      CROSS ROADS
      Vehicle:
      '15 Transit 350
      Can't compare to other brands, but pretty sure Transit was designed to make self-maintenance difficult. Instead of engineers they were designed by mad scientists.
      • Like Like x 3
    • ntimevan
      Jul 2, 2010
      8,635
      855
      Ratings:
      +16,791 / 18 / -2
      Carrier:
      Road Runner
      Vehicle:
      promaster
      Mad , you say...
      Common Sense doesn't come with Directions
    • Moot
      Confused
      Dec 26, 2005
      10,764
      1,005
      Ratings:
      +7,289 / 5 / -1
      Carrier:
      Panther
      Vehicle:
      No just Abby Normal.
      • Like Like x 3
    • piper1
      Adorable
      piper1 Veteran Expediter Owner/Operator
      Sep 22, 2007
      1,804
      330
      Ratings:
      +1,355 / 4 / -0
      You suggested diapers on the Transit forum and you invented something that looks like a catheter......how old are you getting Moot?;)
      • Like Like x 2
      • Funny Funny x 1
    • purgoose10
      purgoose10 Veteran Expediter
      Nov 24, 2010
      2,408
      160
      Ratings:
      +481 / 0 / -0
      What might help with the oil filter on 3.5 is an auxillary filter. Lucas sells them. Attach it to the original filter outlet on the engine then run the line to the filter which you can install on the firewall or whereever. I used them on chevy P/up's and chevy c/vans. Makes life a lot easier. You can also get them with a dual filter setup.
      • Informative Informative x 1
    • robin280
      robin280 Seasoned Expediter
      Jul 6, 2013
      11
      70
      Ratings:
      +14 / 0 / -0
      When I'm home, I take my Transit to my Ford dealer. Everything there is expensive except the oil change. For less that $50 I get synthetic blend oil change and also a tire rotation. I have found that it's almost impossible to get a fast tire rotation on the road because of my high roof and extended length.
      Sent from my SM-G960U using EO Forums mobile app
      • Like Like x 2
    • RoadTime
      Paranoid
      Jun 30, 2008
      5,163
      905
      Ratings:
      +8,247 / 10 / -0
      Carrier:
      Load One
      Vehicle:
      Sprinter
      I wonder if the Ford guys have a less mess work around for this. But at that price, I'd be more inclined to let them clean it up ;)
      • Like Like x 1
    • Moot
      Confused
      Dec 26, 2005
      10,764
      1,005
      Ratings:
      +7,289 / 5 / -1
      Carrier:
      Panther
      Vehicle:
      They will when I begin marketing the Mootrol Easy Change Oil Filter Wrench™
      • Like Like x 4
    • Moot
      Confused
      Dec 26, 2005
      10,764
      1,005
      Ratings:
      +7,289 / 5 / -1
      Carrier:
      Panther
      Vehicle:
      I average about $28 per oil change doing it myself with Motorcraft synthetic blend oil and a Fram filter.
      • Like Like x 3
    • scottm4211
      Jan 20, 2008
      7,416
      655
      Ratings:
      +3,882 / 9 / -3
      Carrier:
      Load One
      Moots Awesome Really Excellent Turbo Tool Extractor.
      Marette
      • Like Like x 1
    • Worn Out Manager
      Amused
      Apr 5, 2015
      4,526
      620
      Ratings:
      +10,595 / 25 / -1
      Carrier:
      CROSS ROADS
      Vehicle:
      '15 Transit 350
      My personal preference is to use full synthetic, not synthetic blend. Becomes important (I believe) as you get higher miles, especially with heavy loads and hilly terrain. That being said, my technical knowledge of an oily surface is the film on the top of a martini when you drop an olive in.
      • Like Like x 2
    • Moot
      Confused
      Dec 26, 2005
      10,764
      1,005
      Ratings:
      +7,289 / 5 / -1
      Carrier:
      Panther
      Vehicle:
      I like that but I don't want to end up in a Canadian court for a trademark infringement, you, you wire nut.
    • Moot
      Confused
      Dec 26, 2005
      10,764
      1,005
      Ratings:
      +7,289 / 5 / -1
      Carrier:
      Panther
      Vehicle:
      Nothing wrong with a little olive oil slick on top of gin.
    • Moot
      Confused
      Dec 26, 2005
      10,764
      1,005
      Ratings:
      +7,289 / 5 / -1
      Carrier:
      Panther
      Vehicle:
      Piper should have fun with this.
      A few years ago my daughter was hospitalized. In her room I noticed what she called barf bags. These looked much more practical than those shallow little trays that were once so common. A few weeks ago I bought a bag of them on Amazon thinking it would work for changing the oil filter on my Transit. Early on I tried a plastic grocery bag that was a huge failure. I thought the stout plastic ring on the barf bag, unlike a simple plastic grocery would make it easy to hold up against the block where filter is mounted.
      I thought the barf bag would be a simple, clean and disposable alternative to the juice container. The barf bag was a major failure. I'm staying with the juice container.
      • Like Like x 1
    • Worn Out Manager
      Amused
      Apr 5, 2015
      4,526
      620
      Ratings:
      +10,595 / 25 / -1
      Carrier:
      CROSS ROADS
      Vehicle:
      '15 Transit 350
      I'll stick with a Valvoline oil change center. They don't deliver freight and I don't change oil. My version of Making America Profitable
      • Like Like x 4
      • Agree Agree x 1
    Loading...
    Share This Page
