Heres the skinny,
The truck was running doggy it was a while since I changed the fuel filter and a fuel line was wet at the fitting on the filter housing. So, I pulled the filter housing tore it down resealed the fittings, R&R the fuel Filter, Fabed up and installed new doughnut seals for the fuel line compression fittings, put it together. Fuel filter was filled before starting it almost ran chugged and stalled and will not start. I Worked the hand pump for quite a few cycles and bled the scrader valve, starts to fire and thats it.
Q. What am I missing?
2003 International 4300, 330,000, original injectors.
