Dispatch favoritism will always be a topic of discussion as long as there are humans involved in the truck dispatch process. It is known by drivers and by management to have occurred at FedEx Custom Critical in the past. Does favoritism still exist? Many who did not or will not get a run offer that they thought they should have gotten, will continue to think so.
I can't realistically express an opinion on any carrier other than FCC so my opinions are specific to that carrier, but may apply to others. As many of our EO members know, Rene' and I have been volunteer members of the FCC Contractor Council for quite some time. In that capacity, we have spent well over 30 full workdays sitting with, observing and discussing roles and responsibilities with every level within the organization including customer service agents, dispatch agents, contractor coordinators, Operations Department supervisors and managers. So, let the reader of this post decide if my comments about dispatch favoritism have merit.
One might think that an owner/operator with such on and off duty contact with their carrier's rank and file, as well as management at every level, would occasionally be the benefactor of a run or two. Not so. To our knowledge, we have never received a run offer that we didn't deserve. I truly believe that our dwell time, truck or driver qualification, proximity to the shipper or any one of a number of other variables were used to determine that our truck was the correct vehicle to be used as a solution for a particular customer's shipping requirements. The oversight of dispatchers and supervisors demands adherence to the carrier's non-favoritism policies. With these safeguards in place, I am confident that favoritism for run offers is so rare as to be virtually non-existent. I'm also confident that when drivers are sitting idle for extended periods, while others are moving, they will continue to believe otherwise.
Have you non-believers ever filled out an on-line form only to have it rejected because a field was not populated or you didn't click on the "I agree" field? Well that's about the way it is with the dispatcher screen. If they offer a run on the QC or try to telephonically connect to the wrong driver, the software kicks back the action for the dispatcher to fill out a field explaining the dispatch of the wrong truck. These situations are then flagged for audit by a supervisor. The likelihood of a dispatcher dispatching the same wrong truck more than once, without an adverse recourse, is pretty slim. The likelihood of a dispatcher and a supervisor each agreeing to a similar action is equally slim. Neither dispatcher nor supervisor is likely to place their job in jeopardy for a one time benefit for an owner/operator.
So, the next time you feel that you were overlooked for a run offer that you believe you should have received instead of that other truck, consider each of the following situations to see if they apply to you before you determine that dispatch favoritism is the cause of your sitting idle:
- The other truck is closest to an ASAP pickup;
- A truck one size larger is also qualified for the offer;
- A truck one size smaller may have more dwell time for the smaller load;
- A large truck needed tomorrow at the load destination may be offered any smaller load in order to get that larger truck to a pickup without the need for excessive deadhead;
- A solo driver is limited in mileage/HOS;
- A truck might be locked onto a pending offer awaiting customer confirmation;
- Might be a short solo load but two drivers needed for special handling;
- Load may have required a liftgate and/or pallet jack or other special equipment;
- The load may require a dockhigh truck;
- Other truck may have been dispatched as an escort for constant surveillance requirement;
- Other drivers may have special qualifications required by the customer, i.e. nuclear handling, A&E (ammunition & explosives) handling;
- Might have been a reefer load;
- Other truck may have come into center or been passing thru with a <75 or mini status;
- Your truck have been placed out of service due to expired documents;
- A solo driver or half of the team may have been placed out of service due to expired documents;
- Your truck might be slightly beyond 25 miles of the center of an Express Center, or beyond another carrier's minimum distance to layover point, so you lose some dispatch points to a truck with less dwell time;
- The company software works in whole numbers of time, so you and a truck that checked in during the same hour would be considered equal in dwell even though you've been told that you are next out. This one could be luck of the draw as determined by the computer;
- Computer thinks you are out of hours because your on duty clock started when you moved a fair distance during the day;
- Your telephone is on silent or very low volume and you never heard the phone ring;
- Computer indicates that you don't have the hours of available service to complete a trip.
