There's only 2 rezones ,that i know of, you'll ever needs to use it .
bad air dryer , or a bad air compressor gasket .
at any case ,this is only the symptom, and once rolling it will be the best to address the real cause of the problem.
all aircompressors have an inlet ,that will be the place to funnel in the liquid .
in the Bendix aircompressor ,it will be in the front and back of the head. simply disconnect the hose coming from the airdryer ,and fill it a bit at a time.
(be very careful ,it can suck your hand in and start a black hole)
or you can try the AirHorns - that's why they have a cone shape...
i carry a bottle in winter time. but that's just because i do a trailer D&H occasionally, and if one of the previous trucks have a bad gasket or air dryer, i won't have breaks ...
a good test to see if this is a bad gasket or a bad air drier, is simply looking under the air pressure release valve.
if it's leaves an oily mass - this is the gasket .
