Crank case/coalescing filter part#
2009 trucks don't have a crankcase filter.
You can add one if you want. It'll keep some schmoo from entering the turbo. Take the cap and plastic tube thing inside the housing and toss them. Install cap and filter from a 2011- later truck.
Malamute662
Thanks man! I am having some "bucking" issues during mobile regeneration. I am modifying the ITV as you described this weekend. Do you have any other suggestions? Sometimes it bucks when i hit the accelerator to hard (not during mobile regen) as well like its not getting boost or fuel for a second or so?
The ITV will definitely cause problems with bucking. I'd start with that.
Momentary loss of power can be caused by improper brake switch correlation. The switch that has its plunger depressed when the brake pedal is released is often the culprit. Turn CCW to release, press in until plunger is fully depressed, turn CW to lock it in place.
