Cargo Van cargo van threads
Discussion in 'Truck Talk' started by ebsprintin, Oct 27, 2010.
  1. purgoose10
    purgoose10 Veteran Expediter
    Nov 24, 2010
    2,407
    160
    Ratings:
    +478 / 0 / -0
    Re: the cargo van setup guide
    You will be pleasantly surprised when you change the gear to 3.73. It will be a night and day change for the better.
  2. chefdennis
    chefdennis Veteran Expediter
    Mar 7, 2008
    11,985
    288
    Ratings:
    +25 / 1 / -0
    Carrier:
    Load 1
    purgoose wrote:
    f
    Iam thinking you are right and that it will pay for itself in short order also...and i do need to change the axle before I flash the computer (or re-flash it again after) because the changes take into consideration the axle ratio...either wa, the cost isn't that big on the computer flash, and again, it will pay for itself in short order...
    • chefdennis
      Mar 7, 2008
      11,985
      288
      Ratings:
      +25 / 1 / -0
      Carrier:
      Load 1
      swingout.jpg swingout 1.jpg swingout 2.jpg swingout 3.jpg swingout 4.jpg swingout 5.jpg swingout 6.jpg Finally got tired of getting the generator out of the truck each time i needed to use it, so it was time to build a swingout carrier to mount the generator on. It was built from 4 resse trail hitch parts and a misc material that was welded together the make the platform.
      1st thing I did was use a "eletric cutoff tool" to remove the rt rear bumper extention. then we welded a 6 inch trailer hitch reciever tube to the underside of the bumper at the bumper mounting bracket where it bolts to the truck frame. Then "hitch pin with a 6 inch rise/drop was installed in the "rise" postition. Using the hole where the "ball" would normally bolt on, I used a 1"x5" bolt with 3 bearing sets and a 36" "Combo bar"..this is a 36" long trailer hitch reciever tube that is used to custom fabricate a hitch. That made up the swingout arm...we also used a 5" "clevis pin" to keep the arm locked closed, by running it up from under the grated step bumper thru the combo bar using the hole that would normally be used to keep the hitch pin in place into the combo bar. The hole for the 1" bolt had to be drilled in the bar.
      To the swingout are, we fabricated an "shelf" out of misc metal. That was welded to the swingout arm....The generator is mounted on the platform using small 500 lb straps and a masterlock cable and lock. I will pickup a cover for it later today.
      Here are a few pictures of the setup:
      • Like Like x 1
    • chefdennis
      Mar 7, 2008
      11,985
      288
      Ratings:
      +25 / 1 / -0
      Carrier:
      Load 1
      Generator cover.jpg Generator cover unzipper and open.jpg Was going to have a cover made for the generator, but after looking around , I figured a twin 30 gallon propane tank cover would work..heres what it looks like. As you can see the top unzips so that access is easier without removing the cover.
      • Like Like x 1
    • Doggie Daddy
      Doggie Daddy Veteran Expediter
      Jun 12, 2002
      2,645
      235
      Ratings:
      +285 / 0 / -0
      You missed a great opportunity to add some "bling" with a diamond plate enclosure.:D
    • tintinj8
      tintinj8 Guest
      Ratings:
      +0 / 0 / -0
      thanks for the nice thread....
    • ebsprintin
      ebsprintin Veteran Expediter
      Jul 8, 2007
      1,875
      160
      Ratings:
      +393 / 0 / -0
      Carrier:
      load one
    • paullud
      paullud Veteran Expediter
      Jul 28, 2010
      6,124
      355
      Ratings:
      +1,397 / 1 / -0
      Carrier:
      Cutts Specialized Transportation
      The ability to edit a post does expire.
    • OntarioVanMan
      Thinking
      Feb 12, 2003
      45,224
      1,205
      Ratings:
      +30,798 / 25 / -2
      Carrier:
      Crossroads..now retired
      Vehicle:
      Sprinter
      You get 24 hrs to change your mind...lol
    • ebsprintin
      Jul 8, 2007
      1,875
      160
      Ratings:
      +393 / 0 / -0
      Carrier:
      load one
      I was editing/updating the original post of this thread for years.
      eb
    • OntarioVanMan
      Thinking
      Feb 12, 2003
      45,224
      1,205
      Ratings:
      +30,798 / 25 / -2
      Carrier:
      Vehicle:
      Sprinter
      This new upgrade did away with that
    • Turtle
      Busy
      Apr 5, 2006
      24,329
      1,285
      Ratings:
      +12,253 / 12 / -1
      Carrier:
      Load One
      Vehicle:
      2005 Sprinter
      I vote for making EB a moderator, if for nothing else so he can edit this thread as needed. :D
    • OntarioVanMan
      Thinking
      Feb 12, 2003
      45,224
      1,205
      Ratings:
      +30,798 / 25 / -2
      Carrier:
      Vehicle:
      Sprinter
      I'll 2nd that!!
    • ebsprintin
      Jul 8, 2007
      1,875
      160
      Ratings:
      +393 / 0 / -0
      Carrier:
      load one
      I don't think I'd like the shirt with the target that's issued with the title.
      eb
    • OntarioVanMan
      Thinking
      Feb 12, 2003
      45,224
      1,205
      Ratings:
      +30,798 / 25 / -2
      Carrier:
      Vehicle:
      Sprinter
      You become harden and bulletproof...lol
    • Lawrence
      EO4ME
      Lawrence Founder Staff Member
      Nov 30, 1999
      8,321
      405
      Ratings:
      +995 / 0 / -0
    • MB driving
      Dr Pepper Addict
      MB driving New Recruit Driver
      Nov 10, 2016
      4
      1
      Ratings:
      +0 / 0 / -0
      Carrier:
      Panther Premium
      Vehicle:
      Straight Truck
      I get a bunch of pages not found on the links in the first few posts. Did they get pruned automatically by the system?
    • Lawrence
      EO4ME
      Nov 30, 1999
      8,321
      405
      Ratings:
      +995 / 0 / -0
      Give us an example...
    • MB driving
      Dr Pepper Addict
      Nov 10, 2016
      4
      1
      Ratings:
      +0 / 0 / -0
      Carrier:
      Panther Premium
      Vehicle:
      Straight Truck
      Well in the first post, the first five links after the photo gallery link all go to your custom 404 page.
    • Lawrence
      EO4ME
      Nov 30, 1999
      8,321
      405
      Ratings:
      +995 / 0 / -0
      Okay, I see that. I think I know what the issue and letting our team know. Thanks!
    Loading...
    Share This Page
