SHARP327
WELL THEY REVIEWED MY PROTEST TO THE TICKET AND ENDED UP REDUCING MY FINE TO $50 ONLY BECAUSE I HAD NO OTHER TICKETS IN THE STATE OF LA. THEY ALSO SAID THAT IT IS STILL ILLEGAL TO HAVE THE AIR PRESSURE REGULATOR IN THE CAB BUT HAVING THE SWITCH TO RAISE AND LOWER THE AXEL IN THE CAB WAS OK. I HAD ASKED ABOUT HAVING A SHUT OFF VALVE INSTALLED ON THE AIR LINE PRIOR TO IT GOING INTO THE CAB WHICH WOULD MAKE THE REGULATOR INOPERABLE WHILE NOT IN USE AND WAS TOLD THAT IF I WERE PULLED OVER I COULD DEMONSTRATE IT TO THE OFFICER AND WOULD PROBABLY NOT BE FINED. BUT I GUESS IF IT WAS BEING USED DUE TO A HEAVY LOAD I'D BE FINED! I GUESS I'LL LOOK INTO HAVING THE REGULATOR MOVED INTO THE SLEEPER SOME WHERE.
HEY MCBRIDE! HOW'D IT GO FOR YOU WITH YOUR PROTEST? WHAT THEY DO FOR ONE THEY SHOULD DO FOR THE OTHER OR AT LEAST YOU'D THINK SO! TAKE CARE OUT THERE!
SHARP327
