Last month I had a belt tensioner break. It broke on the pulley arm. Had all new pulleys and belt, tensioner replaced. Last week I had my battery light flash at me. I took the new belt off and found chunks out of the ribs. Placed a small screw driver in the fan of the alternator to test the pulley movement. A working pulley should turn freely in one direction and not in the other. Mine was locked in both directions. Had a spare alternator and tried the same test. It would spin free in one direction, and lock up in the other. The pulley has a clutch and should free spin when you let up on the accelerator, and engage when accelerating.
So I set out to change the pulley.....so I thought. I have a 2005 Sprinter and nothing is easy.
It takes about 30 sec to take off the pulley from the alternator, if you can get to it with the tools. I could not. So instead of removing the alternator I went the short cut way. Yes, this was easier than removing the alternator.
I gained clearance by swinging the A/C, Turbo cooler and Radiator out of the way on the passenger side. Once that was done it took less than 30 sec to change out the pulley. Cost of repair: zero dollars @ about 3 hours work though.
Here is a short video of the correct pulley for the alternator.
Alternator pulley comparsion.wmv - YouTube
And this one
GATES: Alternator Decoupler Pulley - Features and Benefits - YouTube
And this one
