Hi all!! We just got Hino DX2 software (now I just have to learn how to use it) I'm trying to diagnose a P0628 Fault Code. Went through a trouble tree from Mitchell. Tested Ohms on the SCV was within spec, swapped it for another one anyway. Fuel Temp sensor was not within spec. - Replaced. Checked for voltage and ground on SCV connector - Present. Unplugged ECM harness and SCV connector, checked for ground short in harness- None present. Fault code still active. I've ran out of ideas. Anything I can do with the Hino scanner? Thanks for any input!!
