2012 Isuzu NPR-HD Catalytic Converter and DPF Issue
Discussion in 'Truck Talk' started by jon chelton, Jan 22, 2018.
  1. jon chelton
    jon chelton New Recruit Owner/Operator
    Jan 22, 2018
    5
    3
    Ratings:
    +1 / 0 / -0
    Hi,
    I have a 2012 Isuzu NPR-HD with approx 90k miles and am having issues with DPF regen and Catalytic Converter. First off when driving highways speeds, it does a regen about every 125-150 miles. If there is no traffic and moving ok, there is no issues. If stuck in any stop and go traffic, when attempting to regen while driving it fails and MIL light comes on (usually with reduced power light which goes away when turn off and on) with code P0420 (Catalyst System Efficiency Below Threshold).
    When MIL light is on, it does not attempt a regen while driving and manual regen does not seem to work until code is cleared. This issue has happened 3 times in 1 month, the first time was when truck was about 5 hours away, he drove home and it also had code P2463 (Diesel Particulate Filter Differential Pressure Too Low), but that did not occur the next 2 times the MIL light came on.
    Any thoughts?
    Thanks for the help!
  2. Treadmill
    Caffeine Fix
    Treadmill Veteran Expediter Owner/Operator
    Jan 1, 2008
    2,411
    430
    Ratings:
    +3,466 / 9 / -1
    Carrier:
    Load One
    Vehicle:
    2017 Sprinter
    Hey Jon we have a resident mechanic by the name greasytshirt. PM him your situation (cut and paste) your OP and you should get a quicker response.
    • greasytshirt
      Dr Pepper Addict
      greasytshirt Moderator Staff Member Mechanic
      Dec 3, 2013
      2,169
      220
      Ratings:
      +734 / 0 / -0
      It kind of sounds like it's asking for a manual regen (I'm not as proficient with Isuzu). You'll have to park for about 15 minutes to accomplish this.
      If it won't manually regen, you'll have to get an actual diagnosis. There's a million ways that this can go wrong.
    • greasytshirt
      Dr Pepper Addict
      Dec 3, 2013
      2,169
      220
      Ratings:
      +734 / 0 / -0
      Read the last line for P2463. It doesn't explain p0420, which has several causes.
      Edit: Pic removed.
    • jon chelton
      Jan 22, 2018
      5
      3
      Ratings:
      +1 / 0 / -0
      Thanks that makes sense for the p2463, that was the day he drove it back when couldn’t get manual regen to work on the side of the road.
      Thanks
    • greasytshirt
      Dr Pepper Addict
      Dec 3, 2013
      2,169
      220
      Ratings:
      +734 / 0 / -0
      I did some sleuthing. There is a TSB for P0420. Take it to a dealer and get the ecm reflashed. This is a known issue.
      • Like Like x 1
    • jon chelton
      Jan 22, 2018
      5
      3
      Ratings:
      +1 / 0 / -0
      Thanks I will give that a try
      -Jon
    • jon chelton
      Jan 22, 2018
      5
      3
      Ratings:
      +1 / 0 / -0
      Just an update, Turns out someone put diesel in the def tank, needed full cleaning and new catalytic converter.
    • FlyingVan
      Barefooter
      Aug 24, 2011
      1,593
      280
      Ratings:
      +1,819 / 9 / -0
      Carrier:
      Load One
      Vehicle:
      Straight Truck
      Ouch.
      • Like Like x 1
    • greasytshirt
      Dr Pepper Addict
      Dec 3, 2013
      2,169
      220
      Ratings:
      +734 / 0 / -0
      That sucks. It happens all the time.
    • jon chelton
      Jan 22, 2018
      5
      3
      Ratings:
      +1 / 0 / -0
      Just a follow up to this, we are still having issues and are very stuck now.
      Once it DEF/Diesel contamination issue was figured out, the whole DEF system was dissembled and thoroughly cleaned and a new catalytic converter installed.
      After all that work was done, we still get P0420 catalyst efficiency code.
      Any idea where to go next?
      Thanks
      • Bummer Bummer x 1
    • greasytshirt
      Dr Pepper Addict
      Dec 3, 2013
      2,169
      220
      Ratings:
      +734 / 0 / -0
      So there are two different catalysts on here. The DOC, or diesel oxidation catalyst, and the Scr catalyst. Generally the Scr gets damaged with contaminated DEF. The DOC may have a separate issue, or it can be a software issue (did you check for possible updates?). Or it could be a combination of things or a performance issue.
      I'm not sure if these have DOC and DPF sharing the same container like some Hino's, or if there is an After Turbo Catalyst.
      Who is working on it, and what kind of diagnostic tools are available?
      There's one at the shop I can look at Monday.
    Loading...
    Share This Page
