2012 HINO 268 P073D
chromepixels007
good morning i have a 2012 hino 268 with a allison 2200RDS tranmission, truck never had a single problem for the last 3 years
the truck was pulling of a dock and check engine light came on and the transmission gear selector showed E on display, truck was disconected from batteries and work again like nothing happened,
2 months pass and truck was working no problem until it happened again this time was after a shutdown, gear selector showed E on display and truck Wouldnt even try to start completely "dead".
-3 speed sensors for the outside of allison where replaced
parts# 29536408
batteries where pluged back and truck started no check engine light, a couple of seconds after the crank check engine light came on and the gear selector switched from P to E all this happened while the truck was still ON and engine working, truck was turned off and once again it wouldnt start "dead"
- NSBU switched replaced inside the tranmission by valve body
parts# 29542692
Once again truck turned on like nothing no check engine light, second after crank same problem check engine came on gear selector changed from P to E turned truck off and wouldnt crank again this time after a couple of tries the gear selector wont even show up E is completly blank.
-Tempeture sensor control module was replaced inside the transmission
parts# 29546972
same thing truck turned on seconds after check engine came back and E on dashboard.
-TCC solenoid replaced , Pressure control solenoid trim A,B , and SS1 soloneid
parts # 29541898 , 29541896 ,29541895 , 29536833
this is the pdf that shows the solenoids names and locations: 'EDIT' forum wont let me post the link
finally i took the Tcm out and took it to a place to get it 'tested' and was told lost comunication that the tcm was bad,
ordered a used TCM from a salvaged truck with same P/N assembly number etc installed it and the same problem continues, Gear selector on display is on Blank and truck wont even try to crank. tried looking for a electrical diagram to check the harnesses with voltmeter but no luck finding them or the correct volt n omh
All eletrical conections where cleaned with contact cleaner, oil replaced twice, and some basic fuse check not relays as i cant find if the transmission even has one in this truck thanks for your time for reading this post i completly ran out of ideas and my wallet is destroyed ill appreciate any suggestions or leads
Generally when E shows up on the shifter, the TCM has failed. They have a high failure rate. I can look at this a little deeper but until a known good TCM with the correct programming is installed, all bets are off.
I guess you know by now, but no one should ever shotgun parts at one of these things. Get an actual diagnosis first.
The replacement TCM might be good, but they use that computer on all the different Allison transmissions of that era, so there's no telling what programming is on it.
chromepixels007
sorry about the late response and youre totally correct about that but i was pretty much forced to or pay a 1700 tow lol, im planning on taking the used TCM to hino and ask some questions about how the reprograming works.
the TCM i order has the same Assembly # and Customer P/N number it should have the same programming i will upload some pictures when i get to work on the truck this weekend ill update thanks!
Hino won't be able to do anything with the TCM, you need to go to an Allison dealer.
