2007 Hino 268 Goes into limp mode.
Steve Guida
I have a 2007 Hino 268, I will be driving it and it will go into limp mode, I shut the truck down and it resets and runs fine for a while but then does it again. Any ideas on what the cause is? Thanks
The most common causes of limp mode, in my experience, are VNT or EGR failure. Other things can cause this, too. Getting the codes out of the computer is essential for diagnosing.
Steve Guida
Thanks, The dealer said the vnt code. does that mean the actuator is bad and can you change that out without changing the whole turbo
Dejan
Actuator is bad. Had same problem on my truck. You need to change turbo. They dont sale only actuator.
Before you replace the turbo make sure the linkage is lubricated. Also you can take apart the actuator without removing the turbo, there is a thread that I posted pictures of mine when I did it. If the motor terminals inside are not burnt then more than likely you can fix it.
