I have a 2000 Isuzu NPR and the coolant drains fast out of bottle i.e. a couple days. no external leaks. Is it the injector coppers that cause this and the engine to die cause of low coolant?
Repost this in the Truck talk section for best results.I have a 2000 Isuzu NPR and the coolant drains fast out of bottle i.e. a couple days. no external leaks. Is it the injector coppers that cause this and the engine to die cause of low coolant?
Does this thing have common rail injection or a TICS injection pump? Pretty sure a TICS pump, but I'd want to confirm. Aftermarket stand-alone engine protection systems were common, and some had a low-coolant shutoff function. If yours does not have this, then there's probably a different issue causing engine stalling unrelated to low coolant level.I have a 2000 Isuzu NPR and the coolant drains fast out of bottle i.e. a couple days. no external leaks. Is it the injector coppers that cause this and the engine to die cause of low coolant?
In my personal experience, it's just as likely that you've got an oil cooler failure as a head gasket failure.
