05 Sprinter not starting
beachbum
Had to drop the fuel tank on the Sprinter to replace seal, now it will not start. All it does is turn over.
I did as the owners manual says and turn the key on for 30 seconds then try and start still nothing even after trying this numerous times.
Maybe someone else here has had the same problem and can give me different options.
Thanks in advance
beachbum
Thanks for the ideas, brother dropped tank anagin and purged the whole system and it now starts and runs fine. The big test is going to be when I fill it up and see if there is any leaks now.
