Sterling SportChassis Or Peterbilt 330 crew cab Fuel Mileage??
Discussion in 'Truck Talk' started by hummincummin, Oct 30, 2011.
  1. hummincummin
    hummincummin Active Expediter
    Sep 14, 2011
    3
    46
    Ratings:
    +0 / 0 / -0
    Im currently Looking to get into a little bigger Unit then my dodge dually right now. Pulling my 42ft enclosed im getting roughly 12-15mpg at 65mph.
    Im throwing around the Idea of getting into something like a sterling sportchassis, peterbilt 330 crew cab, freightliner M2, etc and buying a 52ft enclosed trailer.
    The power options id take will be either a 8.3 Cummins, or C7cat.
    More then likely they will be hooked to a 6spd alison trans, But id get a stick trans if i can find one in these trucks.
    as for my rear end gearing id make it tall and give the truck long legs as i'd be doing the tuner programer,etc.
    Dose anyone have any experience or knowledge as to what kind of milage I can expect with these trucks pulling that kind of trailer?
    Or maybe someone with a straight truck could let me know what they're getting in there trucks with set up as mentioned above.
    anything helps!
    thanks!
    Mark
  2. greg334
    greg334 Veteran Expediter
    May 8, 2005
    20,280
    538
    Ratings:
    +41 / 0 / -0
    If you are getting 12 to 15, stick with the dually. The others if they get 10, you are lucky. The offset in the cost of fuel alone would justify not getting a bigger trailer or upgrading to a larger truck. 2 to 5 miles per gallon over 100k a year adds up to a lot of money.
    The gearing is set according to the engine and trans combo, with the idea that the ideal "sweet spot" on the engine is generally around 1800 rpms for those smaller engines.
    As for which one, Cummins. Cat is ok, they don't make them any more and parts are getting harder to find with the same thing about proper servicing.
  3. hummincummin
    Sep 14, 2011
    3
    46
    Ratings:
    +0 / 0 / -0
    Thanks for the reply.
    I was reading and it seems the "common" mileage if around 8-9mpg.
    Now with all things considered I do have a heavy foot so I may get even less. who knows.
    but the extra 11ft of cargo space dose fit ALOT of stuff in my business. sometimes an extra few thounsand. over a 4000mile round trip I usually do a week, How much would the 4mpg difference really be in terms of fuel cost?
    Another thing I like about the sterling sportchassis in particular is the sleeper it can come with.
    Another option I was thinking is a toterhome set up with like a 10ft sleeping quarters. if the milage wouldent change. Why not bring all the comforts of home with me?
  4. greg334
    May 8, 2005
    20,280
    538
    Ratings:
    +41 / 0 / -0
    Never seen one so I don't know if they come with a sleeper or not.
  5. Jack_Berry
    Jack_Berry Moderator Emeritus
    May 15, 2006
    3,572
    138
    Ratings:
    +7 / 0 / -0
    Carrier:
    the ability to pay our bills.
    The diff between 12 mpg and 9 is 111 gal over 4000 miles. How much is comfort worth?
  6. LDB
    LDB Veteran Expediter Retired Expediter
    Sep 11, 2004
    15,941
    755
    Ratings:
    +2,853 / 0 / -0
    Vehicle:
    Recliner
    Buy a CAT engine if you want to be screwed by the manufacturer at any opportunity and spend lots of time visiting you local and not local service shops. Buy a Cummins if you want a pretty darn good engine and a little bit better fuel economy. What's the mpg worth? Simple arithmetic. Round numbers for simplification, 100,000 miles a year and $4 diesel.
    15mpg 6667gal $26,668
    12mpg 8333gal $33,332
    10mpg 10000gal $40,000
    8mpg 12500gal $50,000
    So, moral of that story is you guys who admit to lead feet are spending a lot of money unnecessarily as well as a lot more engine wear due to the higher rpm.
  7. jaminjim
    jaminjim Veteran Expediter
    Mar 25, 2002
    3,437
    265
    Ratings:
    +706 / 0 / -0
    4000 miles a week, must be running out west.
  8. bluejaybee
    bluejaybee Expert Expediter
    Nov 25, 2007
    640
    105
    Ratings:
    +66 / 0 / -0
    Carrier:
    ZiPP Express
  9. LDB
    Sep 11, 2004
    15,941
    755
    Ratings:
    +2,853 / 0 / -0
    Vehicle:
    Recliner
    Yes, it is based on my experience where they denied warranty coverage when two shops both said it was definitely a warranty covered repair. It cost four grand when they finally paid a portion of it, bringing it down enough that a lawyer won't touch it and it would cost as much in lost time, expenses and fees to sue them and recover. I presume not every one of their engines is a piece of junk but I know some are and I know the company itself is unethical and will cheat you if they get the chance. I want nothing to do with potential junk and definite crooks. If you are satisfied with them good. Good luck in the future.
  10. bluejaybee
    Nov 25, 2007
    640
    105
    Ratings:
    +66 / 0 / -0
    Carrier:
    ZiPP Express
    I understand and have read many times before of how they treated you. But it is very unlikely that the poster will be buying a truck with a Cat product that has a warranty.
Loading...
Share This Page
