Sprinter preventive Maint.
NorthernBill
How about it $printer shoes, at apx. 360.000, Alt went. 407.000, oil filter housing came unsealed. What next, oil cooler? Or..........rear end, trans, engine. What have you rebuilt or replaced before it broke?
Replaced drive shaft and front struts at 200.000.
Ours is a 2011, bought used in 2013 with 160.000 on it.
Mines in the shop now getting the oil cooler replaced, some seem to have seals go bad others don't. While it's apart having the water pump replaced and belts and pullies replaced as preventative. 435 thousand but the oil coolers been leaking for about 50.
Treadmill
Talked with a MB mechanic recently and he said the lines (seals) leading to the oil cooler start leaking around 400k. Not a fun repair to go through. Because it's a 8-10 hr job. If you want his number let me know. He does it on the weekend at his house
Reactions: NorthernBill
Treadmill
I heard that the oil filter housing cracks very easy and will cause leaking. It is because of a over zealous mechanic cranking it back one. Had mine replaced a while back.
NorthernBill
So the cooler leak was more or less not to bad? How did it show, or where did the leak appear?
NorthernBill
Would like his number, Thanks
Treadmill
Driver side of engine. If you have oil build up on starter then it's a good sign that those seals are leaking. They will leak more in the colder temps than warm.
Not bad in the beginning but like stated it gets worse in the cold. The oil collects on the cross members under the engine and will drip off that to the ground. Usually a row of small drip spots maybe 3 or 4 towards the rear of the motor.
brokcanadian
The oil stain begins at the bottom of the filter, on the same side down the block...a year or two of ignoring it and I'll be able to see it better
DollarSign
Was told by a mechanic since mine is in the shop that these engines mostly hold up at 300k to 400k before problems start. I say turn them back in and buy new ones and start over. LOL
NorthernBill
The oil filter housing leak was pretty bad, good to know that the cooler leak starts more like a seep.
I know one.person with a 4 cylinder. They had issues but that was also a first model year.
DollarSign
Got mine out of the shop Wednesday. New Def heater, New Def pump, New Nox sensors. I also had the rear end fluid and transmission fluid drained and new put in. In all it was $5600.00 out the door. I had Def heater and pump. The only thing left is the Dpf filter and Cadillac converter.
DollarSign
My honest opinion I don't think the 4cylinder are better than the 6cylinder. Just better on the fuel mileage
