Mechanical Oil leak help
Discussion in 'Truck Talk' started by jamom123, Aug 22, 2016.
  1. jamom123
    jamom123 Active Expediter
    Apr 28, 2013
    294
    50
    Ratings:
    +5 / 0 / -0
    Carrier:
    Fedex custom critical
    Hi everyone, I have a 2005 mbe 900 motor. Several months back I noticed a warm up oil leak running down the oil pan. It would pretty much stop once the truck warmed up. I narrowed it down to the o-rings behind the oil filter housing. Spent about two weeks pulling everything off and replacing the o-rings. After the fix no more oil leak. Ran for a few weeks and had the oil changed. Now I have gradually noticed the same oil leak from the same area coming back. I got to thinking and the only thing I could remember doing before the first leak started was using the lucas engine oil stop leak. Well needless to say when I had the oil changed after the fix I used it again. Is there anyway the stop leak could actually be causing a leak? Thanks in advance.
  2. tknight
    tknight Veteran Expediter
    May 7, 2011
    2,933
    305
    Ratings:
    +1,608 / 8 / -1
    Carrier:
    myself
    How many miles on that motor, oil stop leak rarely works, the design behind it is to swell the rubber seals. Any things possible though. With the amount of oil in your motor I would think that the additive would be diluted and be basically useless unless it was a gallon or more. I wouldn't use it.
  3. jamom123
    Apr 28, 2013
    294
    50
    Ratings:
    +5 / 0 / -0
    Carrier:
    I have a gallon put in when the oil is changed. The motor has about 735,000 miles.
  4. Skyline
    Skyline Seasoned Expediter Owner/Operator
    Jul 13, 2010
    68
    75
    Ratings:
    +14 / 0 / -0
    Carrier:
    FEDCC
    Vehicle:
    Straight
    I know these engines well, but I am puzzled. Let us know when you solve the mystery.
  5. Skyline
    Jul 13, 2010
    68
    75
    Ratings:
    +14 / 0 / -0
    Carrier:
    FEDCC
    Vehicle:
    Straight
    I am about to hit 1 million miles. These engines like oils with no additives and check the valve lash at least every 200 000 miles.
  6. jamom123
    Apr 28, 2013
    294
    50
    Ratings:
    +5 / 0 / -0
    Carrier:
    I normally have the overhead ran every 150, 000 miles or so. They are great motors. The leak isn't a bad one I normally don't even have to add oil between changes. it's just irritating and annoying.
    • Like Like x 1
  7. FlyingVan
    Barefooter
    Aug 24, 2011
    1,083
    230
    Ratings:
    +945 / 2 / -0
    Carrier:
    Load One
    Vehicle:
    Straight Truck
    Where do you guys get your overheads done? I want to get mine done in the near future. I have 585k on it and I don't really know how long ago it was done, if at all.
  8. jamom123
    Apr 28, 2013
    294
    50
    Ratings:
    +5 / 0 / -0
    Carrier:
    I usually get the overhead ran at a freightliner dealership.
    • Like Like x 1
  9. jamom123
    Apr 28, 2013
    294
    50
    Ratings:
    +5 / 0 / -0
    Carrier:
    Update on the oil leak, I stopped using the lucas stop leak and went back to the regular lucas. Seems that the leak has pretty much stopped. It really baffled me but it seems that maybe the stop leak was the problem.
Loading...
Share This Page
