Fuel mileage on cat c-15
Discussion in 'Truck Talk' started by aquitted, Apr 7, 2012.
  1. aquitted
    Batty
    aquitted Expert Expediter Owner/Operator
    Feb 20, 2012
    1,530
    120
    Ratings:
    +236 / 0 / -0
    Carrier:
    C & M TRANSPORT # 483
    So reading one of the forums I see the cat c-15 doesnt get very good fuel mileage. Bummer because the stretched class 8 I was looking at has that engine in it. Anybody know how bad the mileage is and what are the preferred engines for fuel economy on A class 8 stretched D unit?
  2. MissKat
    MissKat Expert Expediter
    Oct 2, 2009
    700
    120
    Ratings:
    +102 / 0 / -0
    Carrier:
    Cat Can Do Cargo
    C15 in a kw tractor pulling panther reefer 6 mpg
    Sent from my VS920 4G using EO Forums
  3. Dynamite 1
    Fine
    Dynamite 1 Moderator Staff Member Fleet Owner
    Apr 7, 2005
    3,992
    355
    Ratings:
    +1,137 / 1 / -0
    Carrier:
    Load One
    Vehicle:
    Straight Truck
    We need more info. Make and model, year, trans, gearing. Not all c15's are the same
  4. Dynamite 1
    Fine
    Apr 7, 2005
    3,992
    355
    Ratings:
    +1,137 / 1 / -0
    Carrier:
    Load One
    Vehicle:
    Straight Truck
    Air cleaner and stacks gone or behind the sleeper and its a 6.5 truck. Could be 7 or 7.25 with a few other mods.
  5. zorry
    zorry Veteran Expediter
    May 22, 2011
    6,791
    170
    Ratings:
    +1,025 / 0 / -0
    Would think a straight could do mid 7's . Prefered engine is usually a Detroit. Cummins next in my book. My class 8 n14 got mid 10's as a straight. Today my engine of choice would be '04 or older or '10 or newer due to emission concerns.
  6. garyatk
    garyatk Seasoned Expediter
    Mar 25, 2008
    328
    83
    Ratings:
    +0 / 0 / -0
    It also depends on what model year and first 3 letters in the serial number. I have 3 of them and they get between 6 and 8 MPG as a tractor trailer pulling trailer loads. Bobtailing they have done better than 10 mpg. You also will get more miles out of a CAT. That is why I bought them.
  7. zorry
    May 22, 2011
    6,791
    170
    Ratings:
    +1,025 / 0 / -0
    The biggest factor is the driver. 35% improvements best to worst drivers in large fleets. Tire pressure also a big factor on overall cost per mile of operation.
  8. aquitted
    Batty
    Feb 20, 2012
    1,530
    120
    Ratings:
    +236 / 0 / -0
    Carrier:
    07 freightliner cst 120 435 h.p. 3:23 rears 10 speed auto shift.
  9. LDB
    LDB Veteran Expediter Retired Expediter
    Sep 11, 2004
    15,952
    755
    Ratings:
    +2,868 / 1 / -0
    Vehicle:
    Recliner
    Caterpillar is a dishonest company that will deny your warranty and cheat you if they possibly can. Go Cat at your own risk. Cummins is a better engine with better mpg and a better company backing it up.
  10. highway star
    highway star Veteran Expediter Owner/Operator
    Oct 13, 2001
    5,249
    555
    Ratings:
    +1,172 / 0 / -0
    Carrier:
    C&M Transport
    ???? I've never heard of that being the case from anyone, be it a driver or an experienced mechanic. Do you have any backing for this statement?
  11. garyatk
    Mar 25, 2008
    328
    83
    Ratings:
    +0 / 0 / -0
    When I was doing my research, and finding out what I needed to do to get the most efficient trucks, I talked to many different sources. The suggestions I followed I were based on what made the most sense to me. My choices were Freightliners with CATS or Detroits or Volvo's with Cummins. I wanted 13 speed transmissions and the only thing I could get with that was Freightliners with CATS. The advice that I was given was that the CATS were best suited for the ECM upgrades that are available, and when you add the torque and horspower that we added, the CAT would be the best motor in the long run. I spoke with a man that did some of this tuning on an MBN and it is still running strong at 1.5 million miles with no onerhaul done yet. I believe that as long as I get good drivers, and give them proper maintenance I will see that kind of service also. I like my solid 7mpg, and my drivers like 600hp and 1850 ft/lbs of torque.
    Do I have proof? NO! But I felt it was best for what my choices were.
    Now to better answer this posts first question, I guess if I was looking to stretch a class 8 to make a D unit I would look for an 07' Volvo 780 with a Cummins and auto trans. You don't need what I have in a D unit, but I wouldn't be afraid of a CAT, especially if it is out of warranty...
  12. highway star
    Oct 13, 2001
    5,249
    555
    Ratings:
    +1,172 / 0 / -0
    Carrier:
    C&M Transport
    Are you doing heavy haul? 600 ponies will certainly get some work done. Good drivers make all the difference, keep them happy and you should be as well.
  13. garyatk
    Mar 25, 2008
    328
    83
    Ratings:
    +0 / 0 / -0
    No, just regular tractor trailer work. But it is nice to get good MPG and the drivers to be able to climb hills like they are empty... :)
  14. Dynamite 1
    Fine
    Apr 7, 2005
    3,992
    355
    Ratings:
    +1,137 / 1 / -0
    Carrier:
    Load One
    Vehicle:
    Straight Truck
    07 would be the last year I would do. No dpf, right. If so it could be ok. And I would say a 9mpg truck to start. I would much rather have a Detroit though. And a 12.7 Detroit at that. The 10 auto and 3.23's should be fine for this set up also. I would be looking at 03, 04, and 05's with this set up if it were me, just don't have faith in the newer models unless you are going to buy a brand new one.
  15. zorry
    May 22, 2011
    6,791
    170
    Ratings:
    +1,025 / 0 / -0
    I'm glad its working for Gary. His drivers must be well disciplined to use the hp wisely. If he gets large enough to get less selective about his drivers he may loose fuel and tire mileage. As a truck hauler I sold my '01 Star at 445,000 miles. I wasn't even thinking of drive tires yet. I was shocked when I learned my high hp co-workers were happy to get 225-250,000 out of there drives pulling the same loads. These were the 1850 ft lbs of tourque guys. If Gary doesn't have a fuel mileage bonus I'd suggest he plan for one in the future.
Loading...
Similar Threads - Fuel mileage
  1. Moot
    17
    1,451
  2. geo
    4
    552
  3. chillout
    6
    751
  4. chillout
    367
Share This Page
