MOndays update, spent the day driving to cleveland to pick up trans, weeeeee nice and shinny and new, bought 18 pints of oil for it, gee you would think it was liquid gold, pints? Had to return the new clutch because my old flywheel had the Pilot bearing ($18.41)shift and spin in place, thereby tearing up the flywheel, so instead of going original, I opted for the much heavier duty newer clutch kit, ran me an extra 500, but I know it's better quality with many more pad surfaces, still comes with the same plastic mounted throwout bearing, hope it lasts longer than the original one, which melted slowly over 135,000 miles a few years back, this will be the third clutch kit, and hopefully the last, service nmanager says the originals were junk, and wore out quick, I concure!
Get this, there is a fix for the walking pilot bearing, it's 2 of the same flywheel bolts with washers welded to them, traps the bearing tight, so it won't spin or walk, normal flywheel bolts are 3.48 each, the modified bolts with the washer are....................drum roll, please, over 25.00 each, 2 required! Does it ever stop?
Tuesday update
So now I'm south of dayton, after dropping all parts off to be reinstalled, I find I can't wait at the truck shop, no where to nap, so I head for a hotel down the road, to chill, then comes the call...... pressure plate bolts are wrong size, have to get from dealer, well, no one has them, so have to order them rush, will get tommorow, another setback, and another 60.00 going back to watching Star Trek in spanish.................could be interesting. Wish me luck.
tk
A side note, for those of you who have this same drive train, mercedes motor/trans/rear end. If you take your truck to speedco, or TA, for that matter any shop, and they top off your trans, they will be doing wrong, they use the wrong oil, even if its spiralx shell synthetic, it's wrong, it will eat the syncros, burn up and turn black, stop lubricating, and you will copy my last 2 weeks. There is only 1 oil, and you have to get it from freightliner, 14.00 a quart, if they have quarts, or in my case it was 6.90 a pint! x 18 pints. Mixing synthetic oil is a very bad no no, and if they add dino it's sudden death, turns to sludge in less than 2000 miles.
I'm becoming a guru on the subject.
Use only the approved Mobiltrans SHC® DC fluid.
Do not mix fluid types. Adding SHC 50 RN 2952
E-5 fluid (used in Eaton and Meritor transmissions)
could damage the radial seals.
