2010 sprinter dpf filter clogged
Discussion in 'Truck Talk' started by Hightech_Hobo, Mar 11, 2012.
  1. Hightech_Hobo
    Hightech_Hobo Expert Expediter
    Feb 28, 2005
    184
    133
    Ratings:
    +0 / 0 / -0
    Just thot I'd pass this ill maint. Issue on and see what the comments would be....
    Dpf filter clogged up at 160 k....MB dealer cost to replace around $2300.00 plus labor....Found a place to clean filter for around $500.00 + shipping...
    2 different MB dealers refused to remove/re-install filter citing legal issues....got freight liner dealer to remove...ship and reinstall filter...lthey charged $800.00 to do this ...
    Overall cost for this issue came out to around $1600.00.....
    This will happen again in around 130k to 200k miles....
    Any suggestions guys?
  2. ChrisGa23
    ChrisGa23 Expert Expediter
    May 11, 2009
    1,147
    113
    Ratings:
    +2 / 0 / -0
    Carrier:
    Load One
    Don't idle the engine. Number one cause of dpf related issues is idling. Idling a few minutes isn't gonna hurt anything but I would never idle any longer
  3. Hightech_Hobo
    Feb 28, 2005
    184
    133
    Ratings:
    +0 / 0 / -0
    Espar heater was one of my first purchases....I have Idled a VERY small amount..but we're talking probably less than 20 hours total in 1.5 years of use....
    I did get one tank of bio-fuel but fuel tank label states must be less than 2% bio so I never did that again...(had no choice on that one tank as I was gonna be stuck on side of road if I did'nt get fuel.....
  4. golfournut
    golfournut Veteran Expediter
    Jul 12, 2009
    1,825
    140
    Ratings:
    +204 / 0 / -0
    Haven't heard of this problem. I have a 2011. Hope it ain't so!
    Sent from my PC36100 using EO Forums
  5. Turtle
    Busy
    Apr 5, 2006
    22,384
    1,285
    Ratings:
    +9,293 / 10 / -0
    Carrier:
    Load One
    Vehicle:
    2005 Sprinter
    Yeah, idling and even just driving in cold ambient temps can block a DPF due to unburned fuels. It's important that you use a 47 Cetane or higher diesel fuel, which means the fuel will burn quicker and more completely, thereby dramatically reducing the amount of soot an ash in the DPF. Most diesel in the US is 40-44 cetane, some even less. Gray bottle Power Service Diesel Kleen® +Cetane Boost® adds 5-6 cetane numbers (white bottle adds 3-4 numbers).
    The DPF needs to reach and maintain optimum operating temperature, which is above 500° F. Idling won't do that. On very cold days, an airflow restriction needs to be in place to help the DPF get hot.
    I think the lifespan of those filters is about 100,000 to 150,000 miles, but a "forced regen" at highway speeds every now and then will help prolong them.
    Instead of Mercedes or Freightliner dealers, look at Cummins or other truck centers. Many will clean a Sprinter's DPF for around $500. In the near future the number of places that clean these things should increase, and the prices should start to come down.
  6. LDB
    LDB Veteran Expediter Retired Expediter
    Sep 11, 2004
    16,013
    755
    Ratings:
    +2,931 / 1 / -0
    Vehicle:
    Recliner
    So about a 1.5-2 cpm operation cost on that item if you can't do part of it yourself and/or prices come down some. Thank you EPA etc..
  7. geo
    Bashful
    geo Veteran Expediter Charter Member Owner/Operator
    Nov 30, 1999
    2,158
    210
    Ratings:
    +443 / 2 / -0
    Carrier:
    ceva
    Vehicle:
    Sprinter
    you need to clean the system out about 40,000 to 60,000 adblue tank needs
    to be clean out and flushed to
    also using ace's 2 helps to
  8. highway star
    highway star Veteran Expediter Owner/Operator
    Oct 13, 2001
    5,249
    555
    Ratings:
    +1,172 / 0 / -0
    Carrier:
    C&M Transport
    Get a Harley before we do the Tail of the Dragon.
  9. briggie1
    briggie1 Seasoned Expediter
    Jul 7, 2011
    59
    75
    Ratings:
    +1 / 0 / -0
    dont idle is a big one and make sure you are using the correct mb number oil,,alot of people think they are but are using the wrong oil {mobil one esp not just any mobil one oil}. i got 300,000 out of my dpf before it got plugged in my 2007 sprinter, and i removed it and sent it away and got it cleaned for around $500 including the shipping
  10. Marty
    Marty Veteran Expediter
    Aug 17, 2002
    327
    135
    Ratings:
    +11 / 0 / -0
    Does using the variable high idle switch to ramp up the idle work to prevent clogging up the DPF. I'm a northerner so I can't stand the heat. I need to run the van for the air conditioner during the summer or I can't sleep on the road.
  11. LDB
    Sep 11, 2004
    16,013
    755
    Ratings:
    +2,931 / 1 / -0
    Vehicle:
    Recliner
    What is the high idle rpm of a Sprinter with the fixed high idle and what is the rpm range with the variable high idle? What is the fuel usage at high idle?
  12. cannedmeat27
    cannedmeat27 Expert Expediter
    Jan 1, 2008
    626
    120
    Ratings:
    +120 / 0 / -0
    I drive a 2008 sprinter. The basic idle is 680rpms. The high idle switch bumps it up to 1500.
  13. OntarioVanMan
    Thinking
    OntarioVanMan Veteran Expediter Owner/Operator
    Feb 12, 2003
    42,168
    1,205
    Ratings:
    +23,978 / 12 / -2
    Carrier:
    Crossroads
    Vehicle:
    Sprinter
    Holy crap Leo.....In the 05-06's the fixed high idle was 2000 rpm...which was required to keep the EGR clean...the newers one might be the same....which it sounds like a race car....Buying a new one with the intention of idling...not such a good move unless you have deep pockets...IF I were to buy a new one now...a rooftop A/C, an Espar with a generator would be a must....
  14. OntarioVanMan
    Thinking
    Feb 12, 2003
    42,168
    1,205
    Ratings:
    +23,978 / 12 / -2
    Carrier:
    Crossroads
    Vehicle:
    Sprinter
    that is better then the 2000 rpm the 05-06 were set at....the difference between the 5 to 6 cyl..
  15. Marty
    Aug 17, 2002
    327
    135
    Ratings:
    +11 / 0 / -0
    I have the variable high idle switch. I can vary the idle from 1,100 rpms to redline.
  16. LDB
    Sep 11, 2004
    16,013
    755
    Ratings:
    +2,931 / 1 / -0
    Vehicle:
    Recliner
    2000?? Wow, I bet that does sound like a race car or a freight train. I'm not planning to buy one to idle but was just curious what sort of high idle numbers it generated. When I drove the truck I had to idle one night when the Rigmaster was down. The normal idle was about 550-600 rpm. I used the cruise buttons to bump it up to 850-900 rpm. I really had no idea where it should be but figured a 50% increase sounded good. I had no idea but thought maybe 1200 and that that sounded high. 2000. Wow. :eek:
  17. OntarioVanMan
    Thinking
    Feb 12, 2003
    42,168
    1,205
    Ratings:
    +23,978 / 12 / -2
    Carrier:
    Crossroads
    Vehicle:
    Sprinter
    You really have to get off the idling....Sprinters don't like it...
    • Like Like x 1
  18. OntarioVanMan
    Thinking
    Feb 12, 2003
    42,168
    1,205
    Ratings:
    +23,978 / 12 / -2
    Carrier:
    Crossroads
    Vehicle:
    Sprinter
    1200-1300 in that range is where I set mine.....as you see from one post the new ones are down to 1500....a little better
  19. Marty
    Aug 17, 2002
    327
    135
    Ratings:
    +11 / 0 / -0
    I set mine at 1200 t0 1300 also with the variable high idle switch. 1500 seems a little high to me but I am wondering if that will keep my DPF from clogging.
  20. OntarioVanMan
    Thinking
    Feb 12, 2003
    42,168
    1,205
    Ratings:
    +23,978 / 12 / -2
    Carrier:
    Crossroads
    Vehicle:
    Sprinter
    That would probably be the Mercedes recommended setting.....Like ours is 2,000 recommended for the egr to keep clean...
Loading...
Share This Page
