2010 isx- 450 hp
zorry
A fellow truck hauler was telling me about his newer truck, a 2010 Volvo with an ISX, no def.
He bought it at 488,000 miles. It used a gallon of oil every 5,000 miles. He changes the oil every 15,000 miles. 95,000 miles later he only uses a gallon every 10,000 miles. He thinks the previous owner didn't change oil often enough. Are his rings just freeing up from cleaner or better oil ?
He says it takes 9 gallons of fuel to do a regen. He said it often regens 3 times a day.
I said that didn't sound right. He says Cummins says that's about right with his oil consumption.
He gets good mpg.
Any comments ?
Another friend is looking at a similar set up.
Dynamite 1
sounds like a possibility. truck could have sat for a bit. the poor maintenance could be part of it.
however, i would stay away from the ISX cause of the cam issues they have had with that engine.
Scotimier
A friend of mine and I both had similar Freightliners with Detroit series 60 motors. We both would have to add oil before the next PM service if we ran Rotella, but wouldn't have to add oil if we ran Mobil Delvac motor oil. I eventually sold my truck to him at 635k miles, and it made it to 1.4 million miles before he had it inframed last year. I always changed my oil in the 10k to 12k mile range. I only ran it to 15k a few times out of necessity, and never liked to run that many miles between oil changes. The oil would get really cruddy looking, and my fuel mileage would begin to drop off as well.
Right now, I run for a small company(12 Cat and cummins powered trucks) that uses the 15k mile pm service interval, and every truck we have uses oil between services. Personally, I think 15k miles is too many, but I don't own the company or pay the bills... I know of some fleets that run 20k mile intervals, but they also trade their trucks in before they're out of warranty.
Deville
I've been doing some research on the ISX motor. The people who have posted about them in various forums have all had nice things to say about them for the most part.
Dynamite 1
google, 2010 ISX cam issues and read the truckers report plus a few others. they also have oil filter plugging issues along with egr issues.
paullud
Change your research methods. The complaints and major issues with that motor are pretty bad.
BobWolf
Sounds like a maintenance issue. 9 Gallons of fuel for a regen and it kicks on several times a day?
At 600 K it may be long over due for a filter cleaning or if the regen was neglected it may be bigger issues.
Found this clip on truckers report. Hope it helps.
excessive regen cycles 14.9L ISX 2008 volvo
Now a quick lesson on engine oil and lubes in general.
Oil is an Oxy morn.
Its a sealant, its a solvent, its a lubricant, its a coolant it transmits heat, its providing extreme hydraulic force and pressure, its providing a soft cushion. Oil dose allot of different things and it is happening all at one time.
So running oil to the 15,000 mile limit might look good on the PM budget. But how about the component R&R I would rather have the oil test guy tell me I can run further on the oil I already changed
Rather than have them tell me the wear metals are off the chart and I had better find a buyer quickly.
Bob Wolf.
BobWolf
Also what about that Pesky EGR system?
Valve, plumbing, cooler? I know coolant will destroy a catalytic converter Im sure it will cause havoc with the smog scrubber too. From my understanding there are precious metals in the scrubber like a catalytic converter for a gasoline engine.
Maybe, possibly a weak head gasket?
Bob Wolf.
zorry
He seems fine with the truck. Claims Cummins told him he's fine and he's just running.
Pulling a dropdeck hauling vans, cut vans stacked, Isuzu COEs, and Hinos ( stacked) he gets 6.5-7 on winter blend and 7.5-8 on summer blend. Figured with a calculator every tank. No adjustment for the regen fuel.
Dash display shows better mpg.
